Where are files saved?
psherman
Post by psherman »
When I save the file I created, where is it stored? No matter where I select, it is saved under another program's name. When I click on the file I have saved in your software, it is opened with the other program. How can I get your program to open the file that I have created in your program? Where is it?
Re: Where are files saved?
Thank you for posting your query.
psherman wrote: Sat Dec 09, 2023 8:37 pm When I save the file I created, where is it stored?
The file will be saved in the same location/folder which you selected.
psherman wrote: Sat Dec 09, 2023 8:37 pm No matter where I select, it is saved under another program's name. When I click on the file I have saved in your software, it is opened with the other program. How can I get your program to open the file that I have created in your program? Where is it?
It seems your file is associated with that other software. To solve this problem, please follow these steps:
1. Right-click on that file and then select Open with > Other.
2. Select TextMaker from the list.
3. Check the option “Always open with”.
4. Click on the open button.
Next time onwards, whenever you will open this file, it will open with TextMaker by default.
Return to “FreeOffice TextMaker 2021 for Mac”
