Bug: Double Enter
silph
Bug: Double Enter
Post by silph »
TextMaker for Android recently updated itself. The "About.." box now says "TextMaker NX - IME (rev S1207.1128.906) 64bit".
I use Textmaker with a Samsung Galaxy Tab S6 Lite, with an Arteck HB 030B bluetooth keyboard. After the update, when I press the Enter key once, TextMaker acts like the Enter key has been pressed twice.
For example, if I type "Hello<Enter>Goodbye", I will get the word "Hello" on its own line, then a blank line underneath, then "Goodbye" on its own line. If I then press <Enter> once, two newlines will be typed out. If I then press Backspace once, it deletes one newline; and then if I press Backspace again, the other newline will be deleted, and my cursor will be immediately after the 'e' at the end of the word "Goodbye".
This bug only appeared with the updated TextMaker. I wish I knew how to undo the update.
Re: Bug: Double Enter
Thank you for sharing the feedback, but we are unable to reproduce this problem.
Please rename folder /SoftMaker/Settings and then check this problem again.
silph
Post by silph »
I don't understand your instruction: "Please rename folder /SoftMaker/Settings and then check this problem again.".
What folder am I supposed to rename to "/SoftMaker/Settings"?
On my Android tablet, I do not have access to system folders with program data. I would have to connect my tablet to my Windows laptop and change system folders through my Windows laptop. Is that what you really want me to do??
silph
Post by silph »
may i have a response, please? i don't understand what "Please rename folder /SoftMaker/Settings" means.
Yes, you will find SoftMaker folder in your internal storage in which please rename Settings folder and then check this problem again.
silph
Post by silph »
I went to Internal Storage on my Android tablet (using a USB cable connected to my laptop), and renamed the /SoftMaker/Settings folder to "SettingsRenamed".
The double enter bug still exists. I have attached a video of the bug.
Please tell me how to get rid of the bug, or please tell me how I can downgrade to TextMaker 2021.
Screen_Recording_20231216_162009_Office TextMaker DoubleEnter Bug.mp4
(354.3 KiB) Downloaded 5612 times
Thank you for trying the step. Please reinstall all three apps and then check again.
Markgm
Post by Markgm »
I can confirm.... I have TextMaker NX Home - IME (rev S1213.0421.920) 64bit
I'm on Android 13, on a Galaxy A9 tablet, with bluetooth keyboard and mouse.
Very consistently, when I hit enter, I get a double enter. 100%.
I have forwarded the details to our developer team.
Adora
Post by Adora »
Hello. I recently bought a Samsung A9+ tablet to use for school. I use a bluetooth keyboard, a Logitech MX Mini Keys. I am having the issue described here. I really want to use Textmaker for my assignments but it really is annoying having the enter key go down two lines. I've been trying other apps none have this issue, but I really want to use Textmaker!
I have tried the recommended fixes above. I've reinstalled the app multiple times and deleted/renamed the SoftMaker/Settings folder.
If there is any new information on this, that would be great.
Thank you.
I have forwarded details again.
icer22x
Post by icer22x »
Using the Logitech K380s keyboard and am also getting this response. Shift+Enter is a temp. fix, but I'd like for the Enter key to work normally again.
okeducation
Post by okeducation »
iClever IC-BK60 on Android 13, Samsung OneUI 5.1 can confirm same double enter issue. Only this app has the issue.
Return to “TextMaker NX for Android”
