Dear ladies and gentlemen,
as an editor using libreoffice on linux and word on windows, I recently heared many good things about your software TextMaker. Thus I decided to migrate. But immediately after startup of TextMaker, a barrier becomes visible: the blinking cursor.
For twenty years I succeeded in switching off any blinking cursor: under linux and windows, in word, libreoffice, in several text and code editors and in terminals for system administration. But not in TextMaker. In the latest version for linux I found no switch to stop the blinking cursor.
I understand the general purpose of a blinking text cursor. But for me personally this is a barrier: I am not able to filter out the blinking but perceive it all the time. A habituation does not happen. The result: My concentration is disturbed.
Humans with an impaired ability to filter out sensory input are not a rare species. A web search for "blinking AND cursor" yields for numerous apps detailed tutorials how to stop the blinking cursor. I am very grateful for these tutorials.
In a nutshell: TextMaker is not barrier-free for me.
Thus I would like to ask you: Could you provide a tip how to stop the blinking cursor?
And if a switch for the blinking cursor does currently not exist: Perhaps it may be easy for softmaker's development team to implement such a switch? This would be very helpful for persons with impaired sensory filter.
I am looking forward to your response
Temprano
TextMaker not barrier-free: How to stop the blinking cursor?
Re: TextMaker not barrier-free: How to stop the blinking cursor?
Thank you for posting your problem. Disabling or making any change in blinking text cursor is operating system level settings. So, please check your operating system settings and that will be implemented in TextMaker also.
I think what he mans is that he would like an option to make the block/bar/text cursor steady instead of blinking. Some applications like Terminology allow you to do such thing.
Thank you SuperTech for your reply.
My operation system is OpenSuse Leap with Gnome as desktop environment. In Gnome I switched off the cursor blinking through the menu Following a recommendation of Jurta https://jurta.org/en/prog/noblink, settings.ini files for gtk-3 and gtk-4 have been configured with the entry:
For apps not integrated in Gnome but for example in KDE/QT, the cursor blinking has been switched off in separate config menus/files.
These are my settings on OS level now. The result: In all apps the text cursors are visually quiet. With one exception: TextMaker.
Thus the clarification of the following points may lead to a solution:
Temprano
Code: Select all
Settings > Accessibility > Text inputCode: Select all
gtk-cursor-blink = 0These are my settings on OS level now. The result: In all apps the text cursors are visually quiet. With one exception: TextMaker.
- Why does TextMaker not respect settings which other apps respect?
- Would this be different in another desktop environment, e.g. KDE or Xfce?
- Would this be different under Windows?
Temprano
Thank you for sharing additional information. I am able to reproduce this problem and forwarded the details to our developer team.
Yes, on Windows, this issue is not there.
@SuperTech:
Many thanks for forwarding this to SoftMaker's development team and for sharing your observation that the TextMaker cursor under MS Windows respects OS settings.
This is encouraging.
Regards
Temprano
Regards
Temprano
blinkingCursor
Not OP, but I wanted to follow up on this. I have the 2018 version of SM Office, which also has this issue on Linux. I will gladly pay to upgrade to the current version of SM Office if this bug has been solved in the current version. Has the blinking cursor not respecting system settings on Linux been fixed yet?SuperTech wrote: Fri Dec 15, 2023 6:18 pm Thank you for sharing additional information. I am able to reproduce this problem and forwarded the details to our developer team.
Currently, we don't have any update from our team, but I have forwarded the details again.
Whenever I will get any news, I will update you here.
Consider me another very interested (Linux Mint) user by any update on that question.
