Default Comment layout
StevieW
Post by StevieW »
Hi....I am trying to set a default Comment style but I cannot get PlanMaker to save my defaults.
I am adding a Comment to a cell, then right click, select Edit Comment, right click the Comment and select Object Mode and finally right click again and select Properties.
I then set the fill colour, shadow shape etc., click on Set as Default then finally click OK.
I then add a new Comment to a cell but it has not remembered any of my Comment settings.
Am I doing something wrong here?
Thanks.
Re: Default Comment layout
Thank you for reporting this problem. I am able to reproduce it and forwarded the details to our developer team.
StevieW
Post by StevieW »
That's great thanks.
StevieW
Post by StevieW »
Do you think this will ever be fixed? It has been over a year now since first reported. If not, is there an .ini file I can edit or create so that I can make the Comments look as I want them?
Thanks.
Sometimes, delays occur due to technical constraints and workload. Please rest assured that our team is doing its best to address the issue.
I have forwarded the details again, and we appreciate your patience. Thank you!
StevieW
Post by StevieW »
Okay, thanks for your time.
StevieW
Post by StevieW »
18 months and still no fix. "our team is doing its best to address the issue" - I really wish that the bugs would get sorted.
lgsl
Post by lgsl »
You payed good money for Free Office? Didn't you noticed the «Free» on the name?
StevieW
Post by StevieW »
I paid for the "full" version as well thinking it might be better.... but both versions have the same bugs.
Shame because I really like the software. I enjoyed using it but the bugs are a bit annoying.
Thank you for your time and patience. Whenever I will get any news from our team, I will update you here.
Return to “FreeOffice PlanMaker 2024 for Mac”
