Transferring Setup Template File
kilogulf59
Post by kilogulf59 »
The title was probably not worded correctly, therefore I’ll simply explain what I want to do and perhaps someone can assist me. My wife and I use the same computer at times (HP Laptop Win 10). I have Textmaker all setup just the way I like it. I put Textmaker on her profile. Is there a file I can copy from my Textmaker to make hers look and work the same? I can’t imagine trying to manually adjust everything.
Re: Transferring Setup Template File
Thank you for posting your query. Yes, we have advance feature available in SoftMaker Office using which you can export and import all settings.
Please click on File | Options | Manage and then export all the settings from your profile and on her profile, please follow the same procedure to import all the settings.
kilogulf59
Thank you, I'll give that a shot.
kilogulf59
SuperTech wrote: Tue Nov 28, 2023 3:14 pm Please click on File | Options | Manage and then export all the settings from your profile and on her profile, please follow the same procedure to import all the settings.
OK, I have no Options tab on my File menu. The only Options tab I have is on the Tools menu and that has no Manage tab. Perhaps I should mention that I have the free version of TextMaker?
Then you'll have to copy the Documents\SoftMaker\Settings from one computer to the other
Maybe also the Documents\SoftMaker\Templates folder too
kilogulf59
OK, thanks. I will give that a try.
kilogulf59
I copied both folders over and it works just fine. Don't ask me to find them again, it was pure accident. Thank you very much.
kilogulf59 wrote: Thu Nov 30, 2023 1:21 pm
Are you using the classic interface?
Tools > Options opens a pop-up window with several tabs across the top. Ignore them. Toward the lower left is a box labeled "Manage."
kilogulf59
Woody44 wrote: Fri Dec 01, 2023 6:10 amAre you using the classic interface?
Honestly, I don't know which interface I'm using. Insofar as the Tools/Options menu is concerned, I have no Manage tab anywhere.
kilogulf59
That's pretty much what I did. It worked. I really should save a copy of those folders/files for future reference, JIC.
kilogulf59 wrote: Fri Dec 01, 2023 12:41 pm
That's not surprising, since neither Miguel-C nor I said it was a tab.
kilogulf59
kilogulf59 wrote: Fri Dec 01, 2023 12:41 pmInsofar as the Tools/Options menu is concerned, I have no Manage tab anywhere.
Semantics? OK, the word "manage" does not appear anywhere.
Post by Jossi »
kilogulf59 wrote: Sat Dec 02, 2023 1:42 pm OK, the word "manage" does not appear anywhere.
Could it be that you are still using SoftMaker Office 2018? The "Manage" feature was introduced with SMO 2021. Or is it FreeOffice?
kilogulf59
It's got to be Freeoffice, I'm not paying for it :D
Post by Jossi »
FreeOffice doesn‘t have this feature. This leaves you with the option to copy the "settings" folder.
