How to copy options/settings to another computer
Princy557
Post by Princy557 »
Hi
I think the subject says it all.
How do I copy the settings to a different computer?
Does it make a difference if it goes from a W10 to a W11 machine?
Regards
Princy557
Re: How to copy options/settings to another computer
Post by Jossi »
Hi,
when you go to Tools > Options, there is a button „Manage...“ in the lower left corner of the dialog box. It allows to export your settings and to import them into another instance of SoftMaker Office. W10 or W11 doesn't make a difference, as these are internal settings of SMO.
Princy557
Post by Princy557 »
Thanks Jossi,
Worked a treat, I'd totally missed that one.
Regards
Princy557
