Wifi printing using Android Print Platform
DarkAngel
Post by DarkAngel »
Samsung Galaxy S6 lite print to Brother HL L3230 CDW...
Once the premium features have been unlocked... Printing can be arranged
WIFI Direct printing works through Brother Print and Scan app only.
  • Print option requires manually searching for .docx file in database
    It prints ok with options you would expect
WIFI Lan printing works directly through the Textmaker Office app.
  • Print option using the Android Print Platform seems to work best
    The .docx file is uploaded into the Brother print app as a preview, however it is not stable as it comes and goes each second or so.
    You can change the print options when the print preview appears but it is a bit hit and miss.
    Printing sends data to printer if you can hit the print button while it is there, before it disappears and returns again.
    A4 paper source option allows 2 sided printing
    A5 paper source currently does not allow 2 sided printing... which is annoying, the option is there but it does not print 2 sided
Re: Wifi printing using Android Print Platform
Thank you for posting your issue, but we are unable to reproduce this problem.
Maybe there is some issue with your printer app or configuration, so please reinstall your printer/“Brother” app and restart your printer, then check again.
Return to “BETA TextMaker NX for Android”
