Template for a new page on a worksheet
Princy557
Post by Princy557 »
Hi,
Brain freeze is in full swing. :o :o
The bottom line has the + sign to give you a new worksheet.
But, Is there a way to have a worksheet template so that you can add a fixed format form to it?
I have a sheet which I want to use as if it were a template itself, currently, I have just got a single work page template in position Tab 1. I copy and paste this each time I have to add an item. Let us say an Invoice where 90% is fixed data. 10% users entered.
Regards
Princy557
Re: Template for a new page on a worksheet
Right click the tab.
Copy > Right
Princy557
Post by Princy557 »
Thanks, Woody44
That's basically what I am doing at the moment.
I was thinking along the lines of multiple-page templates to choose from.
But the way I'm doing it and your suggestion work OK.
Regards
Regards
Princy557
Princy557
Post by Princy557 »
Thanks, Petroben,
Worked a treat, not sure why I missed it! Age me thinks.
Regards
Regards
Princy557
