A more modern file browser
Post here topics for SoftMaker Office NX and 2024 for Linux that do not fit in any of the application-specific subforums.
fadi
Post by fadi »
Your file browser uses folder trees and is a little hard to navigate. Can you make it a little more modern and easier to navigate like this file browser from another office app.
Re: A more modern file browser
What's wrong with the fie browser in the upper image?
bombadillo
Post by bombadillo »
They use a more modern file browser if you're using some desktop environments, such as Gnome or Linux Mint
So do we when you use Gnome.
bernado82
Post by bernado82 »
@fadi
I'm using KDE Plasma as my desktop environment and to have a better file selector in SoftMaker Office I add the environment variable "XDG_CURRENT_DESKTOP=GNOME" to the application launcher. Alternatively, you can launch TextMaker by typing the following command in a terminal:
Code: Select all
XDG_CURRENT_DESKTOP=GNOME textmaker24
Go to the options menu and check that the "Use system file dialogs" box is selected.
ChipTunes etc... is my public playlist for Spotify (a truncated version is on Deezer also) with nearly 1800 titles and over 110 hours of listening, go to: open.spotify.com/playlist/1juVxm3beomqM38isNZRIj
bernado82
Post by bernado82 »
Unfortunately, the command XDG_CURRENT_DESKTOP=KDE does not work for my KDE desktop to get the REAL file's selector in all SoftMaker Office applications. If it worked, this is what it should look like on KDE Plasma?
Leigh
Post by Leigh »
"Use system file dialogs" is greyed out for me
I guess this is because I am not using a Desktop, just i3 windows manager?
Any ideas how I can get the file browser other apps use (I think its Thunar based?)
I am on ArchLabs
bernado82
Post by bernado82 »
"Use system file dialogs" option is greyed out for me also if I launch any SoftMaker Office application WITHOUT using environment variable XDG_CURRENT_DESKTOP=gnome in parameters. KDE Plasma is my desktop on openSUSE Tumbleweed & Leap. I've used Manjaro a little bit in the past, mostly with KDE but also with XFCE as desktop environment. But with i3 as window manager, I don't know if you have the same possibilities of changing the file selector in SoftMaker Office.
Leigh
Post by Leigh »
Thanks!
If I launch textmakernx with
Code: Select all
XDG_CURRENT_DESKTOP=GNOME textmakernx
then the option is not greyed out (I also tried XFCE and I3, but only GNOME worked)
Then I can set it to "Use system dialogs' and thereafter whenever I launch with
Code: Select all
the option is remembered and I get my Thunar file browser :)
So, I will now include that in my i3 keybinds =D>
Cheers, and Happy Xmas!
Return to “SoftMaker Office NX and 2024 for Linux (General)”
