Switching between open documents
Post here topics for SoftMaker Office NX and 2024 for Linux that do not fit in any of the application-specific subforums.
bombadillo
Post by bombadillo »
Can you please make the keyboard shortcuts to switch between open document tabs Ctrl+Tab and Ctrl+Shift+Tab, like in browsers?
Re: Switching between open documents
Thank you for posting your request. We already have "Next window" command with the keyboard shortcut Ctrl+F6.
If you want to change the keyboard shortcut command, you can right-click on the blank space and select "Customize Quick access toolbar...".
bombadillo
Thank you for your response. Ctrl+Tab would be a bit more intuitive but it's all good if you want to keep it how it is.
Return to “SoftMaker Office NX and 2024 for Linux (General)”
