File name on PDF export issue
dvdcppl
Post by dvdcppl »
I’ve noticed that when I export a PDF file, it uses the name of the last exported PDF file rather than the name of the source file.
Re: File name on PDF export issue
Thank you for reporting this problem. I am able to reproduce it and forwarded the details to our developer team.
dvdcppl
Post by dvdcppl »
I don’t fully understand the issue. Some times it seems to use an incorrect file name (the name of the last exported PDF) but some times it seems to behave correctly. Just to confirm, you have identified the incorrect behavior, yes?
When you open TextMaker, it picks the name of that file and stuck on that file name till you restart TextMaker. After reopening TextMaker, it picks new filename in PDF export. I hope now you will be able to understand the problem.
Our developer team have fixed this problem and the solution will be included in the next Beta of SoftMaker Office for iOS.
Return to “BETA TextMaker NX for iOS”
