Cannot save to OneDrive
srmz
Post by srmz »
I am unable to save to OneDrive
Under (Tools / Options / "Appearance" tab I have checked the box "Use System File Dialogs"
When I navigate to "Files / Open" and press the Hamburger menu at the top left, I can see OneDrive listed there and can open any file from OneDrive
However when I navigate to "File / Save" and press the Hamburger menu at the top left, I cannot see OneDrive listed and so cannot save to OneDrive
Will appreciate if this issue can be resolved as OneDrive is a pop cloud location
Re: Cannot save to OneDrive
Thank you for your post, but we are unable to reproduce this problem. Please make sure that you have installed and configured the cloud app (e.g. OneDrive in this case).
If you still get this problem, please share a screenshot of the Save dialog box with device information.
Return to “BETA PlanMaker NX for Android”
