how to make default options change permanent
mauricebis
Post by mauricebis »
Hello,
This is minor point still slightly annoying. When I ask for the table of contents generation some options are ticked by default. Changing them works and changes are kept as long as the file is not closed. When the file is closed, these options changes are lost and textmaker reverts to its own defaults. I tried to do it in the template file and see if I could get the defaults to my taste when creating a new file based on the updated template. Nops. Textmaker persists with its own defaults.
I tried to visit the .ini files in the settings directory to check if there is an .ini file corresponding to the defaults options of the TOC generation with the view of changing defaults there through a basic text editor. Didn't see any.
Well, not a big deal but it'd be nice that these changes be kept in the template file at least so that I could get the options set to my taste for new documents.
Thanks.
Re: how to make default options change permanent
Thank you for your post. I have forwarded the details...
