beta or not?
seasidepb
beta or not?
Post by seasidepb »
Small question - I've enrolled on the beta programme, and indeed the app page on Google Play says I'm a beta tester, but it also says the app will be updated now on the beta channel. But it looks exactly the same as it did before, including the file dialogue, and there's nothing in the title bar or the app properties to suggest it's a beta. So is the first beta still pending?
Re: beta or not?
After joining the Beta program, Google Play Store will take some time to update.
To verify your installed app, please click on '?'(Help) > About and check the revision details and if Beta mentioned there or not.
Return to “BETA TextMaker NX for Android”
