Modify Bookmark
echan101
Modify Bookmark
Post by echan101 »
Hi how do I modify an existing bookmark to point to a different location?
Re: Modify Bookmark
I don't see any way to do that in the user manual. You can rename existing bookmarks and rearrange them, but there doesn't appear to be a way to edit them. You will probably have to delete the old bookmark and create a new one pointing to the new location.
Return to “FlexiPDF 2022”
