Ribbonbar width Position Horizontal and Vertical
HansMaker
Post by HansMaker »
Hi,
in the ribbon bar are shown the object width and height.
I want to put also in horizontal and vertical position which I can not find in customization dialog.
Any idea how to do this?
Thanks a lot in advance,
regards
stascheit
Re: Ribbonbar width Position Horizontal and Vertical
Post by stascheit »
On the Object ribbon tab you can also find a group named Position.
Click on the group arrow at the bottom right corner of the Position group, a dialog box will be opened.
Switch to the Format tab of this dialog box, here you can find the relevant options at the bottom: Position Horizontal/Vertical
Return to “Presentations NX and 2024 for Windows”
