Feature Request: Option to use file type default for Save As
Hook
Post by Hook »
I raised this during the Beta, but I want to raise it again. It applies across all Softmaker Office programs, but Planmaker is where I run into this so I'm posting here.
It used to be, with SMO 2021, that when I went to "Save As" it would offer my default file format which I had selected. So, if I had imported a csv file and then went to "Save AS" it would offer me the .xlsx format. Pretty much all the time, if I go to "Save As" instead of Save, I want my selected default format. Apparently there are others doing different kinds of things wo prefer the change you have made of having "Save As" to offer the same format as the file being saved.
I personally find this change very frustrating, but I appreciate giving folks choices. It seems this is an easy add to file options. Have a setting something like "Save As uses: with two choices "User default" and "Same file format"
Please.
Thank You.
Re: Feature Request: Option to use file type default for Save As
Thanks for your post. I have forwarded this improvement suggestion...
