How make picture transparent ?
Post by 2249 »
Hello.
I often have to insert picture /.png/ to .pdf document. This picture is a signature. How to make this picture transparent so that it doesn't cover the rest of the content on the page ?
Regards
Re: How make picture transparent ?
Post by Jossi »
In FlexiPDF itself there is no such option. You may select the picture frame, right-click, choose "Image" from the context menu and then "Edit..." or "Edit with..." from the submenu to open the picture in a graphics program of your choice to make it transparent.
As a quick workaround, you may also try to choose "Arrange" from the context menu and then "Send to back". Sometimes this helps, too.
2249
Post by 2249 »
I guessed but wasn't sure. Thanks.
Return to “FlexiPDF 2022”
