CSV file column format
KevKP
Post by KevKP »
Hello
I have imported a csv file from an older version of PlanMaker (from last year) where the contents of text columns are enclosed with apostrophies.
In the new version of PlanMaker, if I save the file in csv format, the apostrophies disappear.
If I choose to save as a csv file with additional options and choose the apostrophy to surround the text, all the columns, even numbers, are surrounded by apostrophies.
Any ideas?
Re: CSV file column format
Thank you for your post. Please send the file in which you are getting this problem.
