Master and subdocuments
jmarc
Post by jmarc »
I am managing a very big document.
It could be easier to me to work with smaller ones.
On MS Word and libreOffice, there is a feature called "Master and Sub-documents". I did not find such a feature in Textmaker. Do you have a solution for this ?
Re: Master and subdocuments
Thanks for your post. Currently, we don't have this feature, but I have forwarded this improvement suggestion.
Is your document divided into chapters, or logical sections?
If so, a work-around could be to open each section or each chapter as a separate file. When you are finished and ready to compile the overall document, use the Insert > Document function to merge each chapter into the master document.
