"Insufficient memory"
Léon
Post by Léon »
At the strangest times, a small screen appears in PlanMaker saying "Insufficient memory". In my opinion, this cannot refer to my computer's memory because there is more than enough of it.
Why does this little screen appear? PlanMaker then crashes, which is very annoying, because you have lost what you have changed in the document.
Re: "Insufficient memory"
Thanks for reporting this problem, but we are unable to reproduce it. We have checked and unable to find any crash report also from your email address which is registered with forum. Did you send us report after crash? If not, please send us a crash report and screenshot of the problem.
If required, please reinstall FreeOffice completely and then check the problem.
Léon
Post by Léon »
Hello Mr. SuperTech,
The little screen did not appear since August 28. It is a very small screen (4*4 centimetres or so).
If it shows up again I will take a screenshot and see if there is a log file.
