Remove Useless Languages
jmarc
Post by jmarc »
Hi,
I usually work with two languages, sometimes I need to add two more.
Anyway, looking in the too much list is painful.
Is there a way to edit the list to remove languages that I'm sure I don't use,
Thank you
Re: Remove Useless Languages
Thanks for your post, but the language list is not editable.
The languages you have used before are however sorted to the top.
