Problem to render font "FiraGO"
Post here topics for SoftMaker Office NX and 2024 for Linux that do not fit in any of the application-specific subforums.
patrickalima98
Post by patrickalima98 »
Hello, I'm having some problems to use any SoftMaker on my laptop with the FiraGO font https://bboxtype.com/typefaces/FiraGO/#!layout=specimen.
When I Try to use the font in my documents, I get this bug render:
The same text with the Impress Libre Office is working perfect:
This bug affects all the TextMaker, Presentations and PlanMaker.
My setup:
Ubuntu 20.04
Intel® Core™ i5-9300H CPU @ 2.40GHz × 8
Mesa Intel® UHD Graphics 630 (CFL GT2)
nVidia 1050 ti 3GB
SoftMaker NX (rev S1202.0723) 64bit
How can I fix it?
Re: Problem to render font "FiraGO"
Thank you for your post, but we are unable to reproduce this problem as download page is not working on FiraGo website.
Please share the font file so that we can check it at our end.
You can share it on forum[at]softmaker.com with the link of this post.
bernado82
Post by bernado82 »
@patrickalima98
The FiraGO font seems to work well with all SoftMaker Office applications. I've also tested it with OnlyOffice, WPS Office and LibreOffice (with LO all font's variations aren't listed in the menu).
Here's the link where I downloaded the FiraGO font for my PC (KDE Plasma desktop on openSUSE Tumbleweed):
https://github.com/bBoxType/FiraGO/releases/tag/1.000
Direct downloading for archive file:
https://github.com/bBoxType/FiraGO/rele ... O_1000.zip
[EDIT] Use this link to get Download_Folder_FiraGO_1001.zip file (all OTF & TTF fonts working!). I've updated fonts installed on my system with:
https://drive.google.com/file/d/150l1zz ... sp=sharing
In the extracted file bBoxType_FiraGO_1000.zip, I found 3 folders (FiraGO_OTF, FiraGO_TTF and FiraGO_WEB). But, ATTENTION, on my Linux only the fonts contained in the FiraGO_OTF folder are compatible! The others in the TTF and WEB folders are NOT displayed correctly. I have installed on my system ONLY the fonts found in the FiraGO_OTF folder. Perhaps you wanted to integrate all fonts from these folders into your system, which explains your display problem with SoftMaker Office NX? I think you ONLY need to install the *.OTF files from the FiraGO_OTF/Roman & FiraGO_OTF/Italic folders.
ChipTunes etc... is my public playlist for Spotify (a truncated version is on Deezer also) with nearly 1800 titles and over 110 hours of listening, go to: open.spotify.com/playlist/1juVxm3beomqM38isNZRIj
Return to “SoftMaker Office NX and 2024 for Linux (General)”
