How to Set the Active Sheet
TheArtfulDodger
Post by TheArtfulDodger »
Hello:
This is likely to be a very simple question to answer but I have searched through the BM Manual and, for the life of me, I cannot find out how to set the active sheet (or change it) once I have opened a spreadsheet file with multiple sheets.
Your assistance is much appreciated!
Sparky
Re: How to Set the Active Sheet
Yes, please check the below code, which will open sheet number 4:
Code: Select all
sub main
	' PlanMaker starten
	pm.Visible = True
	pm.Activate
	pm.activeWorkbook.Sheets(4).activate
end sub
Instead of passing sheet number, you can also pass sheet's name like this:
Code: Select all
pm.activeWorkbook.Sheets("test").activate
