Switching apps
Neno
Switching apps
Post by Neno »
Hi, does anybody else has this problem; when (while on TextMaker) I want to switch to another window on my computer (WIN 10), TextMaker keeps returning to itself? I need to click or press alt-tab several times in order to switch to another window. What could be the cause of this?
Tnx
Re: Switching apps
Thanks for reporting this problem. I have forwarded the details to our developer team.
Neno
Re: Switching apps
Post by Neno »
Hi, I'm still struggling with this: alt+tab while in TextMaker doc keeps returning me back into the document. I have to do Alt+Tab several times in order for that new window to stay. This is very annoying and it lasts more than a year. Now, it's WIN 11.
Tnx
RKanarek
Re: Switching apps
Post by RKanarek »
Dear Neno,
Just to make you feel worse, about a year or two (or three?) ago I was compelled to switch from using Win 7 exclusively to also using Win 10. So far as I know, I have never had the problem you described. I don't know if it matters, but I am using the purchased, non-subscription version.
Good luck my SMO brother!
Re: Switching apps
I have already forwarded the details to our developer team, but meanwhile you can try the following workaround:
1. Please click on ribbon command File | Options | Appearance tab.
2. Uncheck option “Show tooltip”.
3. Press OK to confirm and if required restart the application.
Neno
Re: Switching apps
Post by Neno »
Hi, just to let you know, after som time of testing, unchecking the option “Show tooltip” resolved the issue. Thank you very much for this!
Regards,
Neno
