Seemingly missing References command/button.
Rkuser53
Post by Rkuser53 »
Hi, I have a new installation of FreeOffice TextMaker 2021 (rev F1066.0605) 32bit and I'm struggling to find how to use a bookmark I created.
I've read a lot of posts and may of them that somewhat relate to this subject refer to a References button on a tool ribbon. I don't have that anywhere and I don't see it in the Add/Remove buttons on any of the ribbons so I can add it.
What am I missing here?
I've attached a snip of my toolbars.
Thank you for your help.
Russ
Snap of toolbars
Snap of toolbars
stascheit
Re: Seemingly missing References command/button.
Post by stascheit »
Please note, that the "Cross references" feature - which I assume is mentioned in the posts - is not included in SoftMaker FreeOffice.
It is only available in the commercial versions of SoftMaker Office.
This question should have been posted in the FreeOffice discussion area, not SoftMaker Office 2021.
stascheit
Post by stascheit »
Has been moved to the FreeOffice area now.
