SmartText capitalization
caspar4
Post by caspar4 »
I have created several very short SmartText names like:
d = and n = in h = the
First, TextMaker changes the name "d" to "D". That is not a problem because typing "d" or "D" is expanded to "and" .
Problem is that when I want "The", I can get only "the" whether I type "h" or "H". Is there any solution involving formatting the SmartText
caspar4
Re: SmartText capitalization
Post by caspar4 »
caspar4 wrote: Wed Jul 19, 2023 12:04 am I have created several very short SmartText names like:
I want "D" to expand to "And" and "d" to "and". Can that be one?
Thanks for your post, but as per your description, TextMaker is performing as per your instructions.
I suggest you can define DD, HH also.
