YOU CAN'T SEE THE INSERTED IMAGE
cbfgalicia
Post by cbfgalicia »
I have to work with Word documents and in them there are images and photos inserted. When I open Word with Textmaker, the images do not appear, but the space between the text does appear.
What do I have to do to make images and photos appear in documents?
Thank you.
Re: YOU CAN'T SEE THE INSERTED IMAGE
Thanks for your post. Please check the file format of those images. If it's EMF, that's currently not supported in FreeOffice for Linux.
Please change the image file format to JPG etc.
cbfgalicia
Thanks, but it does not work.
Could you please send us a docx file with the problem?
Return to “FreeOffice TextMaker 2021 for Linux”
