Zotero integration - where to install Zotero?
piosl
Post by piosl »
Does Zotero have to be installed in Program Files for the integration to work? I have Zotero custom installed for a local user and Textmaker can't see it (citation options are greyed out).
Re: Zotero integration - where to install Zotero?
Make sure to leave the Zotero LibreOffice Integration add-on (in Zotero: Tools > Add-ons) enabled.
piosl
Post by piosl »
Integration with Zotero works great, but only if Zotero is installed in Program Files(x86).
It's OK, but this should be indicated in the manual.
BTW
Do you plan to integrate with Zotero 7? (it's currently in beta)
piosl wrote: Thu Jul 20, 2023 6:16 pm Do you plan to integrate with Zotero 7? (it's currently in beta)
Currently, we don't have any plan or date as it's in Beta phase.
stascheit
Post by stascheit »
Meanwhile Zotero 7 also works with Textmaker.
Make sure to use for 32-bit version of TextMaker the 32-bit version of Zotero.
And for 64-bit version of TextMaker the 64-bit version of Zotero.
