Where to download Softmaker FreeOffice 2018-982?
Ceel
Post by Ceel »
Hello,
I would to download the 2018-982 release for i386 in .rpm file to install it on an old computer.
Playing with the URL I found the links to download the .deb and .tgz files but unfortunately I'm unable to find the one for the .rpm.
Please, could you post the link to download it?
Thanks in advance.
Re: Where to download Softmaker FreeOffice 2018-982?
Thanks for your post, but we are no longer supporting 32 bit FreeOffice.
Ceel
Post by Ceel »
Thank you for your answer.
I know SoftMaker does not support 32bit release for a while. That's why I need FreeOffice 2018-982-i386, the last release that supports 32bit systems.
I suppose if it's still possible to download the .deb file (https://www.softmaker.net/down/softmake ... 1_i386.deb) and the .tgz file (https://www.softmaker.net/down/softmake ... 2-i386.tgz) it should be still possible to download the .rpm file...
You really don't want to give me the link? :(
Ceel
Post by Ceel »
Thank you very much!
