Can't set new default style
Nebeli
Post by Nebeli »
I can't set new default style of character or paragraph. Each time the same error.
Screenshot from 2023-06-27 23-31-58.png (10.42 KiB) Viewed 37688 times
Re: Can't set new default style
Please do the following steps to check if you have permission to save the Normal.tmvx file
1. Open the Normal.tmvx file via File | Open
2. Type "A"
3. Save the file and close it. Were you able to save it successfully?
4. File | New
5. The new file will have an A in it.
You can now repeat the steps and undo the "A".
While you are at it, you can also right-click the document area > character style > Normal > edit... > and then change the font settings there.
