Hi,
I have been using Excel on Windows using the following functionality, and would like to move to PlanMaker on Android and keep the same or equivalent functionality:
- I have an Excel file with multiple sheets. One sheet (sheet1) contains data from csv files. I regularly pull updated csv files from the internet and store them in the same folder in Windows. This allows me to use the Data > Refresh All function to pull the latest data from the csv file. This updates the data in the sheet linked to the csv file (sheet1), and the cells are then linked to other cells in another sheet (sheet2) so I have all the data I need on that other sheet (sheet2)
- I cannot see this function in PlanMaker. What is the best/easiest way to get the data from the external csv file into the spreadsheet so that I can still have the data from the csv showing on sheet2?
Thanks!
using csv data in spreadsheet
Return to “PlanMaker 2021 for Android”
- SoftMaker Office 2021
- FreeOffice 2021
