Libre Office Presentations
edgarkls
Post by edgarkls »
I just realised that Softmaker Office Presentations cannot open or edit Libreoffice Impress files, which makes the software pretty useless to me. Can support for Libreoffice Impress file be expected in the near future?
Re: Libre Office Presentations
Thanks for your post. I have forwarded your suggestion...
ZekeMX
Post by ZekeMX »
Hello,
I have the same problem, all LibreOffice formats are a must, they are open anyway, specifically on Linux.
Regards
ZekeMX
lgsl
Post by lgsl »
I agree. The OpenDocument standard is much more cleaner than MS.
However I think we are a minority. In the past few years I have found plenty of issues with TM's odt support. This issues are now fixed, but makes me believe that if the format was actually popular between SM users, this issues would have been solved long time ago. I wouldn't have been the only one finding issues with styles and comments in documents.
Return to “Presentations NX and 2024 for Linux”
