Hello,
i've just started using your software , it's awesome to have something like this for free , very much appreciated
i just found something that really annoys me :
every time i use a file and modify it and save , it gets arranged under the left column of files i have on the desktop , i have the sorting off because i use the desktop to put every group of files in different position , but your files keep changing their positions when used ...
how to fix this please ?
Thank You .
files change position when modified
Re: files change position when modified
That happens because of the backup feature that rewrites the previous file as BAK before saving the new one.
You can disable it by going to File | Options | Files | Backup and selecting the option "No backup", but then you'll have no backup.
TextMaker 2024 or NX don't have this issue because they save files differently.
- SoftMaker Office 2021
- FreeOffice 2021
