List with cyrillic letters
korotych
Post by korotych »
Hi!
Could you help me please with changing the English letters in the list to Cyrillic letters? I can't find the appropriate setting to do this.
Re: List with cyrillic letters
You can insert Cyrillic symbols using the following procedure:
Insert | Symbol | More... | Set: Cyrillic
If you want to convert existing Western to Cyrilc text, you can do it here, for example:
https://www.lexilogos.com/keyboard/russ ... ersion.htm
korotych
Post by korotych »
Hi! Thank you for you reply.
I guess you didn't understand me or I didn't understand you. So I have changed my TextMaker interface for better understanding the English names of interface elements.
By "list" I meant numbering. Home tab -> Simple numbering -> Format numbering... -> Format <- I need cyrillic letters here.
The attached screenshot should help you to understand what I need.
Ah, now I understand. I reported the issue to the developers.
In the meanwhile, there's a small trick you can do to quickly change language:
1. Right-click the ribbon of icons
2. Customize quick access toolbar
3. Quick search: Dialog language
4. Click on ">>"
5. Close
6. Now you can quickly change the language in the "Quick access toolbar"
korotych
Post by korotych »
It is very unfortunate that this report was never reviewed and the problem was never resolved.
Thank you for following up on this issue. Cyrillic letters are available for numbering in TextMaker 2024.
Please see the attached screenshot. If you haven't upgraded your SoftMaker Office yet, you can do so from our online shop here to access the latest features.
korotych
Post by korotych »
In that case, I'll update to the new version. Thanks!
