Presenter - NX 2024 disables first slide transition in COMPIZ
eijentwun
Post by eijentwun »
I have Tested Presentations-NX 2024 on Ubuntu MATE 18.04 and discovered when Using Compiz-Fusion as my compositor, it disabled the Transition effect of the first slide on any presentation and sometimes chops off the lower part of the screen.....when I change Compositors in MATE Tweak back to Compton it works fine/normal as it should.
Re: Presenter - NX 2024 disables first slide transition in COMPIZ
Thanks for testing SoftMaker Office NX Beta. As you mentioned that without the third party tool, it's working normal, please contact the third party support team/forum for this problem.
Return to “BETA Presentations 2024 for Linux”
