Hi, I have a 300 page document made in TextMaker using text that was given to me. I have it all formatted with headings, quotes, chapter breaks, etc. I just noticed that, scattered through it, the original text has ascii character 12 (form feed) characters where spaces should be. I can take the text out and replace these in a text editor, but when I put the text back in, all the formatting is lost. There are 116 of them in the text. Is there a way to find and replace these in TextMaker?
Thank you for your time,
Don Jungk
Search for nonprinting character 12 form feed
Re: Search for nonprinting character 12 form feed
Unfortunately, we don't support searching for regular expressions, but you can try the following:
1. Create a copy of your file
2. Rename the copy's extension to .zip
3. Enter the zip file and edit the file \word\document.xml in a text editor that supports replacing such characters
4. Do a search a replace
5. Save the file
6. Rename it from ZIP back to its original extension
7. Open it in TextMaker.
5. Save the file
Thank you for your answer. That was a pretty good suggestion. It didn't work out this time because the character I was looking for was apparently used by the tmdx format. When I changed them all, it altered the chapter and page breaks also. But it will be a good technique at some time in the future, I'm sure.
Thanks,
Don
Thanks,
Don
