Software expired
jackintosh
Software expired
Post by jackintosh »
Hi, I installed the beta on my Slackware box but it says the software is expired and therefore not possible to use it or test it.
Any new beta available, or maybe a release soon ?
Re: Software expired
Yes, we launched a new beta this week, version S1111.0529
tlmiller
Post by tlmiller »
Yes, but how do you get the updated version? In the main thread, it says to do the ? > check for updates, but since the existing version expired, this isn't possible. So it's impossible to update.
Please uninstall the installed version of Beta, then download and install the latest one.
tlmiller
Post by tlmiller »
And how do you download the latest one? The general thread that had links to the new downloads: https://forum.softmaker.com/viewtopic.php?f=437&t=23076 simply says for linux
Linux: If you have installed SoftMaker Office via the repository, it will update automatically. You can also choose ? | Check for updates.
Since it's not installed via the repository, WHERE do you get the manual download for the newest beta?
tlmiller
Post by tlmiller »
Thank you!
