Where is SmartChat in the classic (not ribbon) interface?
RJSawyer
Post by RJSawyer »
It's under Review in the Ribbon interface, but I can't find it in the classic interface.
TextMaker NX Universal - Beta (rev S1111.0529) 32bit
Re: Where is SmartChat in the classic (not ribbon) interface?
You need to reset the Standard toolbar for the icon to appear (or customize the toolbar & add the icon).
The next beta will have a menu entry as well.
Return to “BETA TextMaker 2024 for Windows”
