Physical Keyboard with auto suggetion feature
Hitanshu1Rip
Post by Hitanshu1Rip »
I am a physical keyboard user who cant write in any other languages in the TextMaker app. I want the feature to use other langs with the ability to be written with the physical keyborads. and I also wanting the auto suggetion feature in any lang. in the bottom of the cursor like vs code or any other ide as It might be a handy tool and if we want to disable this feature we can do from the tools settings.
raitis.veksejs
Re: Physical Keyboard with auto suggetion feature
Post by raitis.veksejs »
To write in any other language in the TextMaker app you should install keyboard layouts for these languages for a physical keyboard in Android settings. You can also use the auto-suggestion feature for any language, but you should create your SmartText lists for every language you do use.
