How can I link different columns, so the sorting of one affect the others
Domi
Post by Domi »
I have columns A, B, and C in a spreadsheet, and I want to sort column A alphabetically. However, I also want the corresponding values in columns B and C to move along with column A when I sort it. Otherwise, the values in columns B and C won't match up with those in column A after the sort.
Re: How can I link different columns, so the sorting of one affect the others
Thanks for posting your query. To sort multiple columns together, please select all the columns and then start the sorting process.
mistrowl
Post by mistrowl »
That helps not at all. When you select the column you want to use to sort, it deselects all other columns.
Please check Sorting cells section of our user manual here.
