Track changes now comments deletions
HumboldtSteve
In previous versions, when Track Changes was on, deleted text was set to strikeout. Now the text is moved into a comment bubble which makes it harder to track what's been changed and you can no longer separate edits from comments. I much prefer the old method.
Re: Track changes now comments deletions
This is a document setting. It seems the person who created the document you worked on preferred seeing deletions in the comments pane.
Switch via File, Properties, Reviewing, Deletions: Strikethrough.
Devonboy78
If you are opening a document that has not been subjected to tracking changes, and you want to track changes, you have to first go to File, Properties, Reviewing, and click on the Track Changes box. It is set to OFF by default.
TypeDeleteRepeat
It appears I have to do this for every Word document I open.miguel-c wrote: Sat May 13, 2023 8:43 pm This is a document setting. It seems the person who created the document you worked on preferred seeing deletions in the comments pane.
Although strikethrough is the default for new documents, when I open existing documents (created in Word), the default for deletect text is the comments pane. Is there a way to set the default for all documents to strikethrough?
(I am using TextMaker Trial NX)
Default settings can only be applied to new documents. For existing documents, TextMaker uses the settings already stored in that document.
TypeDeleteRepeat
When I create a document in MS Word, the deletions are shown as strike-through. When I then open the document for the first time in TextMaker, the deletions show up in the comments pane. In case MS Word does not store the track changes viewing settings in the .docx file in the same way that TextMaker does, I would prefer TextMaker applies the default setting of displaying the strike-through.SuperTech wrote: Wed Feb 11, 2026 2:58 pm Default settings can only be applied to new documents. For existing documents, TextMaker uses the settings already stored in that document.
Could you please share a sample Word document where you are experiencing this issue? We will investigate and see what can be done.
If your file contains sensitive information, you can send it to forum[at]softmaker.com and include a link to this post for reference.
TypeDeleteRepeat
The example is attached. Created in MS Word. MS Word shows deletions as strike-through. When I open in Textmaker NX, the deletions appear in the comments pane.SuperTech wrote: Wed Feb 11, 2026 3:24 pm Could you please share a sample Word document where you are experiencing this issue? We will investigate and see what can be done.
- example.docx
- (16.22 KiB) Downloaded 1756 times
TypeDeleteRepeat wrote: Wed Feb 11, 2026 5:36 pm MS Word shows deletions as strike-through. When I open in Textmaker NX, the deletions appear in the comments pane.
Thank you for sharing the sample document, but when I opened your document in MS-Word, it's not showing as a strike-through and is only showing in the comments pane, similar to TextMaker. I didn't make any changes anywhere.
Please check the attached screenshot for your reference:
TypeDeleteRepeat
Weird. My Word shows strike-through. I double checked by downloading the document from here. Strikethrough in Word, comment pane in TextMaker.
I am using Office 365, version 2310 (build 16924.20150), and SM Office NX Trial version.
- Contact:
The thing is that track changes are in flux at Microsoft. Originally it was a document option. Now, they are still storing the setting in documents, but ignore it and prefer what the user chose in the UI. We are on a similar path with upcoming versions of SoftMaker Office.
