BETA TextMaker 2024 NX in Microsoft Word 365 US Measurements
Auldjohn
Post by Auldjohn »
BETA TextMaker 2024 issues composing, formatting, and editing US English in Microsoft Office 365 Subscription mode Word DOCx mode.
(Windows 10 Pro PC OS defaults set to English (US) or English (International), Imperial measurements. Time format configured as 24-hour clock, 0000 to 2359. Short Date format customized to YYYY-MM-DD. Microsoft Office 365 Subscription set to same defaults.
  • TextMaker templates and documents by default configured as A4 sheets, metric scale measurements.
    Cannot set default document measurements, rulers, or formats to U.S., Imperial sizes
    Cannot set default sheet size to Letter (8-1/2" x 11")
    Cannot set ruler bar, margins, tabs, to inches and fractional inches
    Print jobs sent as A4 documents, print from cassette. Default Wi-Fi connected MFC smart printer is loaded and registered with Letter in the cassette. Other sizes, media types, envelopes, or photo paper sizes can be loaded and registered in the rear tray.
    BETA Office 2024 NX Help does not provide any context sensitive assistance, nor does Search Help find any hits.
    Spell Check works but does not include a Grammer check
raitis.veksejs
Re: BETA TextMaker 2024 NX in Microsoft Word 365 US Measurements
Post by raitis.veksejs »
The default unit of measure depends on your computer's regional settings (on Windows). For information on non-Windows operating systems, see Settings, Appearance tab. I did test measurement units on my Windows system and it works perfectly also on SoftMaker Office NX Beta. If it isn't selected according to your OS settings (in Windows), try to restart your computer and check if there are no outstanding updates for Windows available.
https://help.softmaker.com/textmaker202 ... of+measure
Return to “BETA TextMaker 2024 for Windows”
