Hi,
What can I do to solve this issue when trying to open a PlanMaker file?
Thank you,
Geraldo
This File Format is Not Supported
Re: This File Format is Not Supported
Post by raitis.veksejs »
You haven't provided enough information about the problem's context. Can you describe how the problem occurred and specify the program version used to save the file? Additional context would be helpful in identifying the problem.
- SoftMaker Office 2021
- FreeOffice 2021
