Unable to install current beta version
piosl
Post by piosl »
Hi,
I've just downloaded 64-bit beta version for Windows and I'm getting 2503 and 2502 errors.
(VirtualBox 7, Polish Windows 10 22H2 guest)
Regards
Piotr
Edit
It may be some problem with my Windows. I was able to install SO by running the installer from the admin command line.
Edit2
1109 update installed without problems.
Re: Unable to install current beta version
=D>
Return to “BETA SoftMaker Office 2024 for Windows (general)”
