Spellchecking
KrzysAU
Spellchecking
Post by KrzysAU »
The good news: Polish spellchecking is on from the start.
The bad news: Heaps of another languages spellchecking are available now, surely it costs memory, see the attached screenshot.
I found that there is no way to remove ones not to be used by clicking on them, perhaps there should be an option of marking and removing the ones unlikely to be used? Like selecting the ones and having right side 'remove' option.
el48tel
Re: Spellchecking
Post by el48tel »
Yes I've noticed that many "choices" or "options" lists by default have most tick boxes checked. I agree. Not a good Idea.
Re: Spellchecking
Thanks for your post. Spellchecker requires very small files to work, which don't cost much of the storage.
This is a fully featured complete office suite and for such very minor storage we shouldn't compromise user experience.
el48tel
Re: Spellchecking
Post by el48tel »
Just a polite question. Not a loaded one. But why is the default "on" rather than "off"?. Why not let the user choose?
Re: Spellchecking
It adds extra complication to the setup process which should be as easy as possible for the user, with as few questions and decisions as possible.
You can delete any dictionaries you don't need.
el48tel
Re: Spellchecking
Post by el48tel »
martin-k wrote: Fri Apr 28, 2023 6:35 pm It adds extra complication to the setup process which should be as easy as possible for the user, with as few questions and decisions as possible.
OK I accept your opinion. I'm an "opt in" rather than "opt out" guy.
KrzysAU
Re: Spellchecking
Post by KrzysAU »
I tried deleting the dictionaries, but was unable to. On the dictionaries list, there is no 'Delete'. Still on the subject, Russian (Moldavian) is installed but the Russian (I believe Russian Russian) is not. I had it to manually install it.
Re: Spellchecking
1. Downloaded Hunspell dictionaries are in %appdata%\SoftMaker\Hunspell
2. Other are in c:\Program Files\SoftMaker Office NX beta\spell\
Return to “BETA TextMaker 2024 for Windows”
