Default Currency Appearance
moneillqs
Post by moneillqs »
Would it be possible to set the default currency appearance to the Ireland format which is €25.00 i.e. the € is in front and not at the back?
PlanMaker NX Universal - Beta (rev S1109.0422) 64bit
Re: Default Currency Appearance
Thanks for your post. Yes, you can set this in your default template file, save it and then all future files will follow this format.
Return to “BETA PlanMaker 2024 for Windows”
