Add Report Templates
Would it be possible to add some report templates to the templates in Textmaker, with cover page which is not counted in the total page number of the document?
raitis.veksejs
Re: Add Report Templates
You have possibility to add such template yourself, currently we have no plans to create special template for this purpose. To create it you should devide your document in chapters, first chapter would be your cover page. Then to get page count without cover page you will insert field which shows actual page count of actual chapter after cover page. Then save file selecting its extension .tmvx
