Editing an Excel file with Planmaker invalidates its access with python module openpyxl
mbb
Post by mbb »
Hi!
I'm working on a small script in python, which, among other things, opens and manipulates Excel files. Upon testing the script, I noticed that if I edit a file in Planmaker, then I can't open it with openpyxl (I haven't tried other python modules).
The error displayed is the following:
Code: Select all
Traceback (most recent call last):
  File "/home/mochobb/projects/cmvfat/tests/cmvfat.py", line 82, in <module>
    wbEDOC=load_workbook(str(fEDOC[int(iEDOC)]), read_only=False, data_only=False)
  File "/usr/lib/python3.10/site-packages/openpyxl/reader/excel.py", line 346, in load_workbook
    reader.read()
  File "/usr/lib/python3.10/site-packages/openpyxl/reader/excel.py", line 299, in read
    apply_stylesheet(self.archive, self.wb)
  File "/usr/lib/python3.10/site-packages/openpyxl/styles/stylesheet.py", line 198, in apply_stylesheet
    stylesheet = Stylesheet.from_tree(node)
  File "/usr/lib/python3.10/site-packages/openpyxl/styles/stylesheet.py", line 103, in from_tree
    return super(Stylesheet, cls).from_tree(node)
  File "/usr/lib/python3.10/site-packages/openpyxl/descriptors/serialisable.py", line 83, in from_tree
    obj = desc.from_tree(el)
  File "/usr/lib/python3.10/site-packages/openpyxl/descriptors/sequence.py", line 94, in from_tree
    return [self.expected_type.from_tree(el) for el in node]
  File "/usr/lib/python3.10/site-packages/openpyxl/descriptors/sequence.py", line 94, in <listcomp>
  File "/usr/lib/python3.10/site-packages/openpyxl/styles/fills.py", line 64, in from_tree
    return PatternFill._from_tree(child)
  File "/usr/lib/python3.10/site-packages/openpyxl/styles/fills.py", line 102, in _from_tree
    return cls(**attrib)
TypeError: PatternFill.__init__() got an unexpected keyword argument 'extLst'
I attached two excel files. It is the same file, but one of them (ending with '0') was edited with MS Excel and the other was edited with Planmaker.
The error posted above already contains the line of code where it fails on the 2nd line (I only try to open the file). The code works normally if the two files are edited with MS Excel, so the problem isn't there.
I am aware this can be a problem on openpyxl side, but I thought reporting this problem here and making the files available could lead the Softmaker team to find some minor flaw which needs to be corrected.
Thank you very much,
EDOC_FATURA_18_04_2023_2.xlsx
(9.99 KiB) Downloaded 5987 times
EDOC_FATURA_18_04_2023_0.xlsx
(12.82 KiB) Downloaded 6138 times
Re: Editing an Excel file with Planmaker invalidates its access with python module openpyxl
Thanks for your post. I have forwarded the details to our developer team.
rim7bo6b
Post by rim7bo6b »
SuperTech wrote: Thu Apr 27, 2023 12:57 pm Thanks for your post. I have forwarded the details to our developer team.
Any updates on this? According to the openpyxl team, the extLst attribute should not be there: https://foss.heptapod.net/openpyxl/open ... ssues/2199.
I am not sure how related this is, but the SoftMaker team seems to have (had?) a strong opinion on this one in 2019: https://forum.softmaker.com/viewtopic.php?t=18826. Maybe that was a too harsh, iff the standard really does not allow the attribute?
Currently, there is no update on this.
egoan82
Post by egoan82 »
Hello everyone, I have the same problem, I have to generate my excel files with libreoffice to use them.
I also attach a slack view where the softmaker file detects it as a binary while the libreoffice one recognizes it as an excel sheet.
This same problem occurs when reading these files with python pandas.
I am waiting for an update that solves this problem.
Greetings from Colombia.
This problem is in openpyxl libraries, as it's unable to handle the keywords from the file. Ideally, it should skip the unknown keywords. So, we can't do anything here. :(
Please post this problem in openpyxl forum.
egoan82
Post by egoan82 »
Very kind with your answer, I am curious that with libreoffice, onlyoffice this problem does not happen, it is only with softmaker :( .
Return to “BETA PlanMaker 2024 for Linux”
