Crash on opening file from filemanager
arth
Post by arth »
I accidentally tried to open the file I was working on from the file manager which caused TM to crash completely with unsaved changes. The behavior is repeatable with any file. Textmaker 2021 behaves as expected and just does nothing if you try to open a file you already have open.
TextMaker NX Universal - Beta (rev S1107.0403) 64bit
Linux Mint 21.1
raitis.veksejs
Re: Crash on opening file from filemanager
Post by raitis.veksejs »
I was able to reproduce the problem and sent a crash report to the developers' team. As soon as there will be any update about the problem solution I'll post information here.
arth
Post by arth »
Many thanks, I can confirm the same behavior in Presentations but Planmaker behaves correctly
Our developer team have fixed this problem and the solution will be included in the next update of Beta.
Return to “BETA TextMaker 2024 for Linux”
